Does anyone know where i can buy rear sway bar bushings for an ‘02 35th an. Cougar? I searched and search but could never find what i needed the rear sway bar is 19mil and all the bushings i find are way to thick to fit in the mounts. It has kind of a clasp style mount. One end slides into a hole in the frame the other is tightened down with a bolt. Thanks!
Discussion Starter #3
Thank you! And yes it is 19mm. I was confused about it too thought they came with 18mm. Maybe the person before me put on a bigger sway bar dunno.
The 18mm bushings will have a little gap but they will get the job done and you will have no problems
