Hello I have brought a cougar emblem that must replace my original trunk ford emblem.
Now I would like to know how to remove the Ford emblem without making scratches. If possible give me step by step info.
Thank you so much in advance
CougarJake
soak it down with some warm water really well . . . then if you want you can use a blow drier to heat up and loosen the double sided tape on it . . . then use some fishing line or dental floss and get it under there . . . using sort of like a saw motion (up and down / back and forth) get under it and cut through that tape stuff holding it on . . . then pop it off . . . use some goo gone to get the rest of the crap off . . . then maybe some rubbing compound and wax so it is all smooth to put your cougar emblem on! good luck :thumbsup:
-Josh
I don't know Cougarlife....I think maybe you should ask cougarXR7 if you can post this. Hell, maybe even ask him if you can take a piss.
