I pulled back the carpeting from the brake pedal area, and drilled a hole in the plastic piece just below the gas pedal. I installed a rubber grommet into the hole. If you poke a small hole in the grommet, it will stretch as more wires are fed through it, it retains an excellent seal. It's damn hard to find a spot, other than that.
I guess you're talking about underbody LEDs? Yea those were a pain. I had regular neon tubes all hooked up, ripped them off for some LEDs. Everything was already all set up, I had all the holes drilled to connect the neons to the car, had the switch to control them ready, and it still took me 3 hours to wire these things up. I had to run all the wires to the driver side fender then through the firewall by our ATX pre-drilled hole. Put the box to control the neons right by the driver's left leg, attached to the dash piece.
