This weekend I got the trans disassembled finally, low and behold the trans is in fantastic shape, little to no bearing wear, gears are all meshing well, all end play in spec, so that was a welcome surprise. I spent some time getting everything cleaned up, then put a coat of primer and paint on it to not only make it look a little nicer, but help prevent it from getting as nasty as it was before.
I'm thinking I'm going to have everything back together by the end of August if things keep going as well as they are, I do have a question, does anyone know where to find this trans-mount insert? I can't find it anywhere:
Edit, also another question, for the sealant is it OK if I use the same RTV that I used for the block/bulkhead or is it another spec that I should use? I also have some permatex grey
