Hey...
Having a bit of confusion about the orientation of the IAT sensor in the airstream. If it is shaped like a lollipop... should it be flat against airflow (like a closed TB plate), or turned on its side so the air flows over it (like the TB at WOT)? Wondering if the actual sensor is supposed to be shrouded by the plastic loop around it or not.
Thanks,
Massiv.
Thanks,
Massiv.
