Okay...here's my question: In the how-to by Spocket, the last section is entitled "Put everything back together". What the how-to doesn't explain is, do you FIRST install the Cougar fuel cup IN the car and THEN attach the Eclipse fuel door to it? The instructions become a bit confusing at that point, because it says to attach the Cougar cup to the new fuel door, and then install the assembly back into the car. This doesn't make sense though, because the Cougar fuel cup must be installed from BEHIND the quarter panel, and the Eclipse fuel door clearly must be installed from the OUTSIDE of the panel. I am assuming that I'm correct in assuming that you install the cup and then attach the door to it, but I just wanted to make sure before I start in on the project and get stuck while trying to put everything back together. CAN ANYONE HELP ME OUT WITH THIS?
Many Thanks,
Charles
Many Thanks,
Charles
