I did it, took me about 5 hours, start to finish (wiring up the inverter, monitor, and PS2, and cutting the glove box to make it fit properly). What do you want to know?
Cut a hole on the left side in the back of the glovebox for the wiring to sit inside of, then double-side tape the unit to the bottom of the glove box. End of install. :biggrin:
I don't know if there's enough clearance on the bottom of the glove box to have it mounted so that it doesn't swing down. The box may slant up too much. But doing it the way others suggested is fine..that's how I did mine..although it's just sitting on top of some stuff in my box...it fits in perfect and doesn't move around.
Any body know where to get lcd's that are already mounted inside the sunvisors? Or is it easy to do?? Im gonna put a ps2 in our cougar also. If someone that has already done it could post a how to I would greatly appreciate it... Also not counting the cost of the ps2. How much am I looking on spending for the inverter, Lcd's in visors, wiring and what ever else I need?
Thank you
BRYAN
1 - 9 of 9 Posts
