So I have become another statistic to a leaking power steering system... It was such a bad leak, it got to the point where I was literally putting a quart in after driving every hour or so... Couldn't figure out where it was leaking from because EVERYTHING was coated in Mercon, but thanks to you lovely people, I was inspired to check the pressure line where it goes into the pump, and lo and behold, the elbow was the culprit.
I didn't want to replace the whole pressure line, as I have plenty of other problems with my car that need attention, and the rest of the lines seemed fine, so after some research, it appeared Autozone had an elbow in stock that was "an exact fit for my vehicle".
Excited to not have to strongarm a gentle curve anymore, I eagerly got into the whole process of putting the damn thing on.... I'll skip all the details and swear words leading up to this, but I was incredibly excited when I finally got it unscrewed from the pump itself and was ready to pop the new one on and put everything back together again, bada boom, bada bing.
Wrong.
This *** thing does not stick out of the pump the same way as the old one. The metal protector thingee gaurding the pump itself is in the way of the elbow sticking out the same way the old one did, therefore it does not line up properly with the hard line that needs to screw into it. When I held the new part up to the old one, it appeared identical, save for minor differences in (what I believe to be) just manufacturer cosmetic designs.
Has anyone else had this issue and what did you do to fix it?
I was tempted to do some engineering and try to gently bend it, but I know how delicate that swivel-y part is, and I'm not trying to create another leak... That plate in front of the pump was about to get some surgery from my dremel until I realized it would never cut through, so please! Anyone?! Help!
Wrong.
