1 - 19 of 19 Posts
If you were to just sell the MAF, how much would you want for it? What is it currently calibrated for?
Bridge, do you have the calibration sheet that came with the maf?
well it would be fair to inform potential buyers about that, that would make life alot easier for your tuner.
no, I already own one, was just being a good samaritan.
So you can probably tell us what are the benefits of that MAF + Optimizer? :confused: It is only for forced induction?
I'll add a bit of info to this.
The Pro-Flow MAF is a great product. To get the most of it, Dyno Tuning is HIGHLY recommended. The calibration sheet is not needed if you get it dyno tuned. I got it done without it.
I would NOT recommend just throwing this on your car because it will run horrible and you can risk damaging your motor.
Also, since it's a Ford based MAF, it may have the incorporated IAT sensor as well and the IAT can be wired up to it.
thank you riken, meant to add that yes, you really need to get tuned to run it [I tried dropping it in my car and it was like, hey look thats cool my exhaust is spitting gasoline]. This is useful for the people sitting around 300ph that have maxed out the stock MAF
1 - 19 of 19 Posts
