Well, Only half right now really. Took me 8 hours or so to get to this point. Hopefully what I have done so far didn't completely screw up air flow. Ill give stats on dimensions later in the post.
Here are some stats on my head/UIM and what I'm hoping the macine shop can do for the LIM
Port. - Stock - Throat Dia. Gain
HEAD RUNNERS - Prim. 1.400" 1.351" +3.5%
Sec. 1.400" 1.358" +3%
LIM - Prim. 1.215"
Sec. 1.259"
UIM - Prim. 1.400" 1.112" +20.5%
Sec. 1.400" 1.232" +12%
TOLERANCE: basically everything is within .005" of each other. Stock casting flash differences were ignored though.
Im hoping to have the LIM machined out to 1.4 as well. I spent a LOT of time matching up all the ports. The UIM ports seemed to be WAY off center with the LIM and heads. Basically the center of the port on the UIM didnt match up with the theoretical center of the LIM or head ports. This took most of the time in porting, as many measurements had to be made to keep a consistent CL and correct Dia. Layout paste, and a nice set of calipers came in really handy.
As the secondary and primary ports enter the LIM from the UIM the runners on the upper make an upside down "V". They severly taper in the closer to the LIM you get. What I found out (after hours of work) is that the runners themselves in the UIM are actually rather smooth, and close to my port-matched size of 1.4". They are a little smaller, but not much it seems.
Anyway, just figured I'd post this as I have nothing better to do on a tuesday night, hehehe.
LIM - Prim. 1.215"
Sec. 1.259"
