A tab was welded in the reinforce the OEM mount as shown here.
A square tube of metal was welded in underneath the oem mount.
Another great upgrade to your suspension while your under there is to upgrade to the Aussie Endlinks. As you can see from the photo below
The aussie endlink is much superior design, and has a rollerball joint so as the sway bar moves the joint will self adjust and will ultimatly provide superior handling and smoothness.
Stock endlink (left)...Aussie Endlink (right)
This is the Aussie Endlink as shown installed. (contact Stazi on CEG to purchase)
