Originally posted by: Instigator
ya man i tried that, but the car takes away power up top, i could thoroughly tell the loss in top end power when i did that.
i personally think these rods and butterflies help with airflow, i do want to optimize the butterflies tho with smaller screws etc...
That makes absolutely no sense what-so-ever!
Having center bar rods & plates through all 12 ports not only takes away from flow area but causes a considerable amount of turbulence and velocity loss.
Removing the plates and plugging the holes picks up the powerband above 4000rpm. Completely the opposite of what you state.
Not only that but it keeps the air form getting hot and stagnant in the secondary ports, speeds up acceleration after shifting, and gives better mid throttle and above performance as well.
Now is losing in town cruising drivability below 2500rpm and a fair amount of low throttle position torque below 3800rpm worth it... That can not be determined by anyone but the driver of said car themself.
Also without the ability to tune the IMRC point you are stuck running with the P1518 CEL to get the low rpm timing increase.
Also cold weather drivability takes a hit as well as the engine is atomizing fuel even worse.
IMO it is probably not worth the trouble on a 2.5L engine and I loved it with mine. I especially loved it when autocrossing or drag racing but then again that nearly describes my normal driving too.
Now a 3L is a different story as the natural increase in overall TQ far exceeds any lost by this mod. Also you would be getting a tuned chip anyway so that takes care of the rest of the "cons" already.
