Ok, so I'm working with a company that would replace the pcv and prevent all the oil vapor from entering the intake. He had a few questions that I'm not able to answer. Below is his questions. If you know the answer I would appreciate the help. Thanks
I assume the the two breather lines from the valve covers are Tee'd together with PCV valve on output of Tee.
Make sure that there is not also a crank case breather on the engine. This breather usually exits the engine & runs to the air intake box & is a larger diameter (~1/2"). With one breather on each valve cover, there may not be a second larger breather?
