PCM
How do i get it out??
just take that bolt off and pull it out to me (above the strut tower)
dont want to mess anyhitng up
Thanks,
Steve
Are you trying to remove the actual PCM or just the PCM wiring harness? If it's just the harness, then you're right.......just remove the bolt.....and lift it out. If you lift out the power steering reservoir first..............it'll make it a lot easier.
yea i need to get it out to tap a wire for my a/f ratio gauge
so i just need the top bolt right??
Yes.........just remove the bolt on the PCM harness connector.......then it'll lift right out.
