upon turning the key to start i get nothing, no fuel pump noise and no attempt to even crank at all. Lights all work as do the gauges but i did notice the security light steadily blinking the whole time. If this is a pats problem would i be better off having a new key made or trying the pats bypass?
full bypass doesn't exsist. Pats light flashing means there is an issue.
Easist fix could be a bad ground/dead battery.
where is the ECM FUSE??
MY CAR DOES NOT CRANK AFTER I DISCONECT THE POSITIVE CABLE WHEN IT WAS RECEIVING JUMPER FROM OTHER CAR
EASY ON THE VIRTUAL YELLING WILD MAN!
The only piece of information we have from you right now is the car doesnt crank when the battery cable is disconnected...No kidding. The TV doesn't turn on when its unplugged either. I assume there's a key piece of information missing here, but we can only guess.
We can probably help you, and will be happy to do so, but you should make a new thread telling us about your car and your issues so we arent trying to make recommendations on incomplete data.
