coil pack going bad?
I know my iacv is bad because of the moosing sound it makes when its cold outside so i ordered a new one and it should be here on friday but lately i have been having a new problem. Sometimes when its cold outside and i try to start my car, it will not start. It sounds like it wants to start but it just wont kick over. I have to try to start it a thousand times until it finally gives in. I know its not the battery or the alternator or the fuel pump, but from a previous post by grandmasterkhan, i think its the coil pack going bad. So i did the little test that someone recommended about pulling out one of the sparkplugs and leave it connected and then starting the car and look for the spark. I seen a spark but i dont know if it was big enough. How big or bright is the spark suppose to be. Lately the car has been having trouble with dimming of the lights even though i already done the alternator fix. I went under the hood and reved up the engine and observed what happened. When i rev the car up and release it the cars idles all the way down and then comes back up and smooths out. Sometimes i think that it wants to stall. I think this is from the coil pack going bad though but can someone please help cause im on the verge of ordering a new coil pack. Oh yeah and the wires and plugs are also good.
