1 - 15 of 15 Posts
My passenger side window only goes down and not up (from the passenger side controls, but the driver can put the passenger side window up and down)
WHats going on?
I just bought it, so I dont know much here.
Passenger side switch is probably bad. The springs and contacts can get worn or bent. You could attempt to straiten it or replace it.
Discussion Starter · #3 · (Edited)
I've never fixed anything on a car (so I probably wont be doing it myself)... should I go to Ford , or a local mechanic or something? How much do you think they would charge?
mine does that also go figure, heard so many people talking about theirs doing that i thought they were made like that. haha
I doubt a mechanic would even know how to fix it. You would basicly need to replace it then, It is VERY easy to remove. Just stick a putty knife or screw driver(i suggest the putty knife) under the edge of the switch, and pry it out. Once its up, theres a small button release on one side. Press that with a finger nail or screw driver and pull it off.
Discussion Starter · #8 ·
I have that problem but it's more of a nuisance as it works for me if you flick the switch a few times :banghead:
I didnt even try that yet :disgust: lol
I might call Ford or something and ask what they would charge.
Moraki... even if I took that out, I would have to get a replacement right, which I dont know where/what exactly to get.
Prepare to be surprised. You would be replacing the switch you popped out, and you can get new ones for about $50, IIRC. A dealer will charge you an arm and a leg to do it, but it only takes about 30 seconds to replace one.
Call Bill Jenkins, tell him which switch you need (passenger window switch in passenger door - that's important), and do it yourself. It really is as easy as Moraki described.
Discussion Starter · #10 ·
I should mention, I live in canada... does Bill deliver?
Or any sites I should look at for a fair price (and delivery price)?
I just went to rock auto's site, I could only find window motors there, no switches.
Discussion Starter · #13 ·
Update*
its not completely broken, I found out that if I actually keep clicking it it will start working...
Does this call for a new switch still, or to fix it?
It will likely only get worse. There is some delicate and intricate parts inside the switch.. they likely wont get better over time.
1 - 15 of 15 Posts
