actually i removed both mirrors to paint the black part, pull of the door panel by removing the 3 screws along the outer side, then there is a screw behind the cougar emblem, then there is 2 screws behind plugs at the bottom of the front of the door, so total screws to remove is 6. pull the bottom out and lift up to remove door trim. take off the door lock by unsnapping it and pulling down, then unplug the mirror and lock plug, and take away the door trim. bend up the rubber trim at the front of the windows, unplug the motor wiring harness and unscrew the three bolts and pull the mirror straight out. make sure not to drop the nuts down in the door, you will never get them out and you will have have a permanent rattle. to put it back on just reverse the order.
