Passanger side A/C vent removal.
Credit to Crispy for the "how-to". I had it saved to my HD but couldn't find it on the boards, so I just wanted to post it again and add my hint to it as well.
When you are looking at your vent, look at it as if it was a clock face. There are two tabs, one at 5 o'clock, and one at 7 o'clock. You can see the tabs if you shine a flashlight directly into the vent itself. You will see the tabs at those positions, inside the vents. I made the mistake of sticking the screwdrivers on the outside of the vents...that doesn't work.
Use two long, thin, flat head screwdrivers and push those tabs in, the vent will pop right out.
