I have noticed that there were a few people asking how to paint certain things.Well I build scale model cars as another hobby and have a few years of painting experience.1st off ,Your paint job will only be as good as your prep.work.You don't have to sand if you don't need to but it is a good idea to"rough"up the surface so the paint will have something to adhere too.Dont use to rough of a paper though.Make sure you Prime the surface with light coats,light coats,light coats!!!!You can wetsand between coats with 400 then 600 grit.If you dont prime 1st and use lacquer it can "etch" plastic.Also your primer color will effect your final color.(White primer of course will make yellow brighter then using grey primer etc..)Candies and pearls need a base coat of silver, gold ,black ect....
After you have fully primed your pieces.Then Start your color coats.Again the 1st coat should be just a mist coat hardly covering the piece.Wait 10 to 15mins between coats With each coat cover alittle more untill you get full coverage waiting 10 to 15mins for every coat.You can wet sand between if you feel it's alitttle "rough"or you get crap in the paint,Dust ect.Then once you have a full color coat coverage you can do a "wet"coat..Thats where the fine line comes in,thats between running and hardly any orange peel.(I would test that fine line before I tried to paint something that I didnt want to look like crap)after the paint has cured.(lacquer 2 or 3 days.enamel a good week or more).Now you can wet sand again.Very light and dont burn through the paint on the edges!!!!(Get the paint "flat"no hills or valleys)then you can clear coat it.Same way as the color coats.Once you have an ample amount of coats on it let it CURE and CURE.It needs to "gas"out..Now here is where the "trick comes in to make that paint look a mile deep with that mirror finish.There are companys that sell "polishing"kits.All it is,Is different grit sandpapaper that will take out all the hills and valleys that you might not see.you start off with "Rough" paper(3200)and and end up with 12000.Yes thats12000grit.make sure you ssand the entire piece with every grit dont skip a grit.(Again you have to be careful on the edges or you will go through the color coat to the primer)The end result will be amazing.This picture really doesnt do this paint justice.Anyone can paint like a pro with a polishing kit..An airbrush is also a plus but the same results can come from a can! Here is one place you can get the polishing kit from.www.detailmaster.com The sanpaper it on a cloth backing and last for about 4 or 5 paint jobs depending on how big of a peice you paint. Anyway I hope this helps..please eamil me with any questions you might have..also if I left anything out please feel free to add.
Rad
Rad
