Crispy knows of my dash painting woes...but here goes
(I'm a poet, didn't ya' know it?)
I have my dash shroud stripped down again. The paint is gone where it used to be rough, it is down to the stock black plastic now, which has been wet sanded smooth. The silver paint that was left has also been sanded with 400 and 600 grit sandpaper, as well as wetsanded with both, so it is quite smooth as well. So basically the whole shroud is smooth, but most of it is still silver from the layers of paint that have been applied. There is quite a large black area, as well as a few smaller spots, where I had to sand the rough spots out. It seems even and smooth now, even though some of the shroud is still painted, and other spots back to stock.
So my question is:
Should I apply the Duplicolor polypropelene primer coat on top of this? Or should I use some sort of plastic cleaner or other prep.?
Is there a certain primer, I have tried three kinds. One was called Adhesion Promoter by Duplicolor, and another was similar, by by a different company, neither seemed to work, they both bubbled, and didn't hold the paint well.
This primer says polypropylene, which I know is good stuff, and it is a white bottle, with is Duplicolor Primer.
Next, I have the silver metal flake that Crispy used when she was going to paint me a shroud.
I used it for my pillars, and I liked it, sparkly as it may be. It worked well on the pillars, and it coats nicely.
So if I use that, should it hold well to this primer, should I wet sand with 600 between coats?
Then should I paint as soon as the last primer coat is dry? Is that the best method?
Then once the paint is dry, should I apply a clear coat soon after?
I also have 2 kinds of Duplicolor clear coat. One is the large can, which is just black, and says Duplicolor clear coat.
It doesn't specify interior, exterior, anything...is this the right stuff?? It doesn't look very special.
I also have a smaller can, which seems to be more for the interior. I think I have tried both on pieces in the past, and didn't seem to notice they were doing much as far as making a really shiny plastic coated layer on the parts I was working on.
Do I wet sand between coats on the clear coat as well? Or just build on top of the others, until the desired finish is achieved?
I would really appreciate as much advice as I can get. I have been working on my interior all summer, and I really want to get it back together now. I hate my car being in a large project stage like this. I want it all back together nicely, so I can concentrate on my next projects
Thanks for any advice you have, especially you Crispy...this would have been so much easier if you would have sent me the peices already painted, I would have probably spent much less money paying you to do it, and it would have looked much better I am sure!!
Nic
