whoa, damn... lots of questions!
ok first Sapien - Thank you!
99CouGSweetRide - the center consol thing is a little tricky... its glued at the top (near the armrest) and I kinda had to "snap" it off... Don't worry, you can hot-glue it back later... so its not permanent.
then the front near the dash, just takes a bit of careful wiggling to get it out
AND as far as I know, that smaller vent up on the dash, behind the passenger circular vent - does just snap out.
XR2002 - I cant think of any diffrences other than using a black color primer, would make the finished job a few shades darker... since black is darker than grey, it would probably affect the finished product.
I used a grey primer... and actually I find the dash a bit too bright-red in the sunlight...
I'm sure if I had used a black primer, then it wouldn't have turned out like that.
any more questions?
