I need to know what is the best type of paint to use when it comes to plastic pieces.With so many products out there you never get a good one till you tried them all.:confused:
I'm looking to paint the fuse box cover,the piece on top of the grill when you open the hood and other pieces.Any help on which one to use?:confused:
El Mucho Post Whoro
If you paint anything under the hood, I suggest using some kind of hi-temp paint. That basically leaves you with (although there are a few other choices) Duplicolor Engine Enamel (available in several colors) or Duplicolor MetalCast (Takes a long time to dry, like 4-5 days for full drying). Always prep the surface with sanding first, and at least two or three THIN coats of primer for adhesion purposes.
alos when you paint plastic you need to spray on some plastic adhesive.Its clear and you have to spray this on prior to any primeing. If you have any questions pm me
