1 - 3 of 3 Posts
Well, one gremlin I have found so far is that the gas gauge is intermittent. I filled it up the other day, and it will go from full to empty, and maybe go back to full. I also got a 460 code set. I am going to go out on a limb and say it almost has to be the sending unit, but thought maybe someone else has had this issue. It did sit for two years with old gas still in it. Any thoughts?
This is going to sound dumb, but what is the status of your alternator? Have you checked the output, or visually inspected it?
Electrical Connections to the pump etc worth a check too
Discussion Starter #3
I think the alternator is fine. Everything electronic is good anyway. I will check voltages. I do think maybe it is a wire going to the tank under the back seat. I pulled the carpet loose and kinda messed with it a bit and then it started working again.
1 - 3 of 3 Posts
