like the title says...imrc stuck open.
i already checked and the cable isnt snapped. the problem is that the imrc wont stop pulling the cable. when i start the car the cable is being pulled even at idle. sometimes the imrc works as normal but most of the time it just keeps on pulling the cable. when i turn the car off the cable comes back down to resting position.
if i unplug the imrc when the engine is on the the valves close, then when i plug it back in the valves open (imrc pulls the cable)
does the imrc have an external grounding wire?
