Ok, so i have a 2.5 ATX. I just got done replacing the original motor that had a rod knock with one that had 57K on it from a salvage yard. When i first fired it up it began to overheat, neither of the fans would come on, then after i rechecked all of the connections (ground wires, etc) and for no apparent reason it all started working with temp being fine. I drove the car for a week or so putting about 150 miles on i without a problem.
Then tonight i was driving along and noticed that the motor seemed a little sluggish, anyway at the next traffic light i noticed the temp gauge in the red...
I don't know how long it was running hot, but i shut it off immediately, waited a minute or so and restarted it to monitor the temp in the diagnostic mode and it was around 252, both fans running on high....so i shut her down and parked her.
Two hours later i restarted her to move her to my son's house 1/2 mile away. Temperature was down by now, fans still working and i turned on the heater full blast...still temp started to climb. I shut it off well before it got into the red this time. Engine ran fine other than the overheating. I checked the oil and it was not milky, nor is there any sign of a coolant leak or the dreaded coolant smoke out of the tailpipe.
So tomorrow i want to fix the thing and i have searched and read the posts regarding overheating, thermostats and water pumps. What i would like to know is how to properly diagnose the problem.
I figure based on what i read that it has to be the thermostat or the water pump...but because i get hot air out of the heater, does that mean that the water pump is working ...otherwise how can tell if water pump is working ?
Anyway, i need help diagnosing the problem...ideas...should i just replace thermostat and see what happens...
j
j
