I have reposted this by request and pictures are a small file size for easy download and little server space.
KKM no longer sells the SVT for the Cougar, because they do not want to make the two simple modifications. I looked at the one Mortis bought in 1999 and realized these would be easy to do myself, and extra parts were only $10.00.
First go to the KKM Tru-rev website via the performance section of the NECO site (not the message board). Print the fax order from and put down that you have a Contour, no need to call and hassle. They won’t sell the parts to do the modifications. Fax it in, and you will receive your kit in a few days. Go to your local hardware store (Home depot is where I went) and buy the following parts:
PlumbQwik P1056-33 3” to 3” hose ($8.00)
½ X ¼ plastic barb coupling (.89 cents)
One foot or shorter ¾ OD X ½ ID vinyl tube (.99 cents) you need at least an inch.
Tools:
Flat head screw driver
Hole punch or Phillips head screw driver (not pictured)
11MM and 8MM sockets or wrenches
Drill with ¼” bit.
Fender cover
Tools:
Drill with ¼” bit.
Fender cover
