J
JSlo
·Guest
I have a 99 cougar with 233,000 km on it. It is a v-6 sport model all stock. It had a tune up at 190,000 km but plug wires were not changed and I replaced EGR valve at 200,000km. This car is riddled with problems and I wish someone would steal it. I am not that lucky so let me explain some of the bigger problems and hopefully I can get some advice.
1. Oil leak at rear main seal. This needs to be repaired and I hope to do it soon. Is it better to pull the engine to do this or do it from underneath? Are there any other repairs that I should do as preventative maintenance while doing this? Is the chilton manual very helpful when doing thi big of a job?
2. Rough idle when cold. Several posts addressed this but none said only when cold. But same story, revs to 2 or 3k then down to 100 and eventually stalls. If weather is warm it seems only to have a slight miss. It also does that thing at high way speeds, that slight hesitation that is almost unnoticeable, especially up hills. Also, I loose brake power at any time. This is inconsistent and happens in different conditions. I cannot find any vacuum leaks in air hoses. So from what I have heard from mechs and now spending the last 4.5 hours reading posts, I need to do the following: replace plug wires, pcv valve, O2 sensors, fuel filter, fuel pump, iacm(sp?), and upper and lower intake gaskets. But in what order should I do this in based on what is the most likely cause? And if I do the intake gaskets, is there anything else I should do while I have it apart? Also, obviously my CEL is on but some time it flashes too. I've had it checked by a code reader and it said something about banks 1 and 2 running lean.
3 Change oil light. Tried exaclty what common problems post said. Didn't work. Tach and Speedometer goes all the way up then returns to zero. Then there is a 13 on message screen and different things show up if I push select. I think some of them are engine temp, voltage and rpm's but one says FLOO and there are some others. This is a Canadian car and my owners manual actually doesn't say anything about haw to reset it. I saw one post that said to diconnect neg. baqttery cable for 10 minutes so I'll try that I guess.
I guess I'm just lost with this car and don't know where to start. I would appreciate it if some one could give some direction in further diagnosing the problems and maybe what order to do the repairs I've mentioned. Thank you to any one who didn't fall asleep in the middle of this post.
