1 - 3 of 3 Posts
Anyone know anything about this? For 295.00, i suppose that's a pretty good deal. I can get hook up's w/ friends and friends of friends w/ the tuning help. I'm assuming you'd need a chip or what not to actually keep the settings? I don't know. Any feedback is wanted and welcome. I just figured this would save a lot of money if you actually could tune yourself rather then shell out $XX.XX amount of dollars for each tune.
That's not a tuner, is simply a air/fuel ratio meter. Now, it does have a wideband sensor that you stick in your exhaust so you get a true reading, but to do any tunning you still need something else.
Yep, what he said ^^^
A standard 02 sensor ranges in signal voltage from .1V to .9V where a new wideband 02 sensor ranges from 0-5V therefore giving you a much more accurate reading.
If you want a complete programmable engine management system, get an AEM EMS system for a 96-xx mustang. You have to re-wire quite a few wires on the harness (well, not too many), change over and add a few sensors, and download a flash from AEM and you'll have one of the best EMS systems around!
BTW, they are able to tune EVERYTHING from a/f ratio, fuel mapping, ignition timing, spark duration, computer controlled traction control (!!), boost controller, turbo timer, idle control, detonation control, rev limiter, and a fully programmable progressive nitrous controller for any NOS system! It even has a datalogger built in!
1 - 3 of 3 Posts
