I run the 5.0 fox body rims and they fit right on; Hub centric & cleared shock. A really wide tire would rub, I use 215/50/16 on them. You might lose about one rotation on lug studs but still safe.. But I'm using different rims so use discretion of course. I didn't need to swap my studs so not sure if those will work. Good luck! Post a pic when you get em mounted!
