Hey everyone, I've had a 2000 Mercury Cougar V6 automatic for about 8 years now, but I have finally decided that I want to learn how to take care of a car myself. Got it with 50k miles, at 127k now.
I was able to pick up a Chilton's manual for Contour/Mystique/Cougar 95-99, apparently they're pretty much the same with the 2000? Plan to change the oil, oil filter, fuel filter(probably has never been changed), engine air filter and cabin filter this weekend.
Hey Frostbite,
welcome to the bunch!
The engines, transmissions, chassis and most other systems on the cougar are the same (or same-ish) as the contour's. They're the same platform, so a lot of the bones are the same. the 1999 and 2000 cougars are also extremely similar - some early ones used a return-style fuel system instead of a returnless one like 2000, 2001 and 2002, but that's the main difference. your manual should do just fine for the jobs you're looking to do this weekend.
note : sockets usually don't fit on the V6 oil pan bolt because of the proximity to the exhaust - you'll most likely need a wrench. Also, the oil filter is right above the front exhaust manifold (grr!) so you might want to use some aluminum foil to divert any leaks off the manifold. I don't - I just deal with the pleasant smell for a few miles, ha-ha. the fuel filter should be on the passenger side, in front of the rear wheel, tucked in nicely. it's held in by a hose-clamp if memory serves - if you search around the forums here, you'll find out how to remove and reinstall the plastic clips that hold the lines on. I haven't touched that in forever, so I'm not sure how it went. I think that's pretty much it.
I hope you continue to enjoy your car and that it treats you well in the years to come. be sure to keep an eye on that transmission - they're not... particularly well liked from a durability / reliability standpoint, but I'm sure you've heard about all that.
Hardest one is the cabin air filter because you have to pull the wiper arms off. Welcome to the bunch
Discussion Starter #4
Thanks for the tips guys! Regarding the transmission: I have seen some posts while browsing that suggest my transmission might be nearing it's end. Anything I can do to prolong it's life? The service manual says to change the fluid at 135k miles. I know I'm pretty late in the game though so wouldn't be surprised if there's not much I can do now.
Auxiliary transmission cooler always helps.
Welcome from a new owner although I've had my '98 Contour about 3 years. I've changed the cabin filter on both without removing the wipers but it's probably easier if you do so.
As for the ATX, I feared the same thing for my Contour. Had it checked by a local shop and they said it was fine. To be sure, I "flushed" (like 5 back-to-back changes) with full synthetic fluid. You could probably change fluid at half intervals after and be fine.
