B
Guest
i installed an indiglo gauges and everything is assembled again, but when the mph needle goes up to 60 the needle just stays there....what should i do?
B
Guest
Discussion Starter #3
do i really have to pull the needle off? or maybe i should just pry it halfway....in that way i dont have to recalebrate?
just keep beating the dash on the top to get the needle to go back down. after a while everything will 'settle' in and work properly. i'm speaking from my own experiences on this. i never moved the needles or anything like that and it took around a week or so for it to work right.
you don't hafta pull the needle off, just pull it out a little bit so it isn't catching on the Indiglos
yeah don't take the needles completely off, I used two spoons and pry'd up just a little bit on each needle getting stuck
