OK, I got my ground controls and installed the fronts yesterday. I went to install the rears today and couldnt figure out how to get the back ones out!! Im sure its something so dumb but i need help!!!
Thanks
take the tire off
that two bolt up by the top of the strut out (from underneath)
take bolt at the bottom of the strut out
remove the sway bar bolt and nut
push down
Ya, if you look up inside the shock tower, ther's (2) 10mm bolts that hold the strut plate inside the shock tower, take those out and the rest is a piece of cake. Later
T3/T4 60-1
if you are having problems removing the strut from the hub assembly... take a jack with a 2X4 standing end-end on the jack cup... use the other end to jack up the strut bracket (where the brake lines go)... then kick down or hammer down the hub assembly... strut should pop out
