i have a question i hope someone can help me out.
do i have to re use the big round black piece that goes on top of the springs that holds the springs together?
if you need more explaining let me know :)
I did an install with " B" from Cooga not too long ago but i cant remember if we did or not. Try PMing him, he should respond.
Ill move this to suspension in the morning. Maybe youll get an answer tonight.
devin ..well i did use that how to on his site..it kinda sucks dont explain much at all ...
and the ground control instructions are the WORST i have every seen ...all i have to say is hand drawin!!
thanks for moving it...i forgot about that section
there is an easy answer to this question
yes, you have to reuse the upper strut mounts on both the front and rear suspensions
BUT
on the front suspension, there is also a seperate metal plate which is the upper seat for the stock spring. although you can reinstall the ground controls with this plate your not supposed to, so ditch this plate and allow the upper perch of the ground controls to rest in the upper strut mount.
simple...
