Mucha appreciado lost racer. I got one out of the junkyard, got it tinted and got it reinstalled. Put everything back together and closed the door. Door didn't close! Glass was about a quarter inch high? Possibly some debris or broken glass in the way at the clamp end or something. By then it was pouring and I'm sneezing. For any future cougar people:
Taking the panel off the door -
1) there are three star head body screws around the perimeter
2) there is a long star head body screw at the bottom hinge side of the door (just a small hole in the felt on mine)
3) there is a long phillips head screw under the black pop out button in the fabric
4) there is a long phillips head screw under the small cougar image button
Lift panel free.
four button connections, brown, blue, green and black; disconnect them
Two phillip heads hold the handle on from the inside; undo them and pull the handle through the panel
put the panel aside.
Good luck. btw, window was 27 dollars used, tint was twenty five dollars.
