UPDATE from B3NN3TT:
As you might have noticed, the hosting has expired on almost all of these how-to documents. I have been able to recover them all from Internet Archive, and am planning to re-index and re-host them once I find the proper place to do so.
Until that time, I have simply dropped everything into a shared folder on a Google Drive, so you can access them - albeit in a random, unorganized fashion - at this link: HowTos - Google Drive
Thanks for your patience.
I've been wanting to do this for a while, So I got with Trevor, he provided the space for me to store all these on the newcougar.org site.
I took all the How-To's I knew of, and put each in a PDF file.
Below are the direct link to each. These are exact copies of the How-To's so I take no credit or responsibility to their content. In each I listed the creator, or the user whom posted the How-To. Enjoy.
In no particular order (Hit F3, and type in a word to find matches)
(more to come w/ time)
NOTE- If you do not have Adobe Reader (or another PDF Reader) Installed you will need to do so before attempting to open these!
Available Here: Get Adobe Reader (It's Free!)
- How To: 3rd Break Light Removal
- How To: Use 65mm throttle body (Mustang TB)
- How To: Replace 99-00 Alternator
- How To: 99-00 Speedo Needle Replacement
- How To: Add shock sensor to factory alarm system
- How To: AIT Relocation
- How To: ATX to MTX Swap
- How To: Change LCD COlor
- How To: Clean upper and lower Intake manifolds w/o removing them
- How To: Clean MAF (Mass Airflow Sensor)
- How To: Clean UIM w/ Seafoam
- How To: Change Coolant
- How To: Modify cup spiller into a CD holder
- How To: Custom Exhaust for Under $200
- How To: Custom * head dash
- How To: Cut the stock shifter
- How To: Install DMD (Dual Mass Dampner)
- How To: Install Eclipse Fuel Door
- How To: End 1-2 Bang Shift
- How To: Fix Dimming Lights (alt wire mod)
- How To: Fix Heater Blower Resistor
- How To: Install FSTB (Front Strut Tower Brace)
- How To: Paint your gauge bezel
- How To: Ground wire relocation
- How To: Install Hood Pins
- How To: Fix IMRC
- How To: Install CAI (Cold Air Intake)
- How To: Install Jaged RSTB (Rear Strut Tower Brace)
- How To: Rebuild your intake system (Remove, Clean, Replace Seals, Re-Install)
- How To: LED Swap For Dummies
- How To: Make MIL eliminators
- How To: Modify Flasher Blink Rate (for LED Blinkers)
- How To: 02 Sensor replacement
- How To: Optimize stock y-pipe
- How To: Optimize stock or SVT TB (Throttle Body)
- How To: Passenger Window Auto Down
- How To: Program PATS key
- How To: Prep Plastic pieces for Paint
- How To: Install push button start
- How To: Recover door panel inserts
- How To: Safely remove driver side airbag
- How To: Remove exhaust manifolds and precats
- How To: Remove center console and replace ATX Shifter
- How To: Replace Cabin Air Filter
- How To: Replace DPFE Sensor 99-00
- How To: Replace shift cables
- How To: Reprogram Key Fob
- How To: Returnless Fuel Pump Replacement
- How To: Reverse Indigo Gauges Install
- How To: Repair Sagging doors (bushing replacement)
- How To: Use self diagnostics mode
- How To: Replace Spark Plugs (2.5L v6)
- How To: Recalibrate needles on speedometer
- How To: Optimize stock y-pipe (2nd version)
- How To: Remove and replace stock struts and springs
- How To: Replace Sunroof
- How To: Install SVT Fuel Pump
- How To: Install SVT TB (Throttle Body)
- How To: Throttle Hang fix (Moosing or Moose Sound)
- How To: Tint or Nightshade your tail lights
- How To: Underdrive pulley Install
- How To: Install Walbro Fuel Pump
- How To: Replace Waterpump
- How To: Wet Sand
- How To: Wussy lock horn fix
- How To: Recover Headliner
- How To: Recover Visors
- How To: Add MP3 Input to the Factory Radio
- How To: 2.0L Zetec Clutch Replacement
- How To: Custom Fiberglass Sub Enclosure
- How To: Install front sway bar endlinks
- How To: Install rear sway bar endlinks
- How To: Remove dash
- How To: Re-route anti-theft horn to main horn
- How To: Rear Disc Brake Conversion
