I have to have a new key programmed..and come to find out someone removed the ODB2 in my 99 Cougar..any ideas on what to do? Can I reinstall it?
What does that even mean?
Onboard Diagnostics II (OBD2) is a diagnostic system that is included in every vehicle made after 1996. It is used to check the engine and other vehicle systems and communicate all the possible glitches that happen to them.
I'm pretty sure there is a communication breakdown here as to what is missing. I'm fairly certain you can't remove the system, but maybe someone moved/removed the port under the dash?
Yeah I鈥檓 assuming he can鈥檛 find the port.
I鈥檓 sure it鈥檚 up there somewhere.
In the unlikely event that someone literally cut out the DLC (OBD2 port) and you need to reinstall it, I do just happen to have this composite diagram I made last year...
81653
