i know this is a long shot. but i need an input shaft from a mtx75 for the v6. the v6 is the longer shaft the 4 banger has the shorter shaft. i know somebody has a transmission torn apart around here
I got a trans out back thats been laying around for years without a shifter in it. I was saving it because I was eventually going to use the case to get powder coated and rebuilt. I've been needing to take it apart and see if the LSD in it is still any good. I guess I could make that happen sooner and see if the input shaft in its any good.
I actually have a friend who does laser welding and he will be fixing the spines on mine but if that doesn't work I am definitely interested because I cannot even find one online.
Theyre pretty easy to remove if you have a press
A press is on the to buy list. Let me know how it goes with your friend maybe I'll have one by then.
Well, considering Quaife still sells the LSD, and the complete gearset, and has made extended shafts on demand in the past for Mondeo/Cougar, I would propose giving them a call.
