Well just bought all my stuff for the swap
98 MTX ( has better gearing for acceleration) change to longer 3, 4 and 5 gears.
low milage tranny
both axels
MTX pcm
clutch master and slave cylinders
brake master cylinder
clutch and brake petal
inside shifter
shift linkages
BRAND NEW SPEC Stage 2 clutch
hopefull my rims sell so i can get fidanza lightened flywheel
and B&M STS
i cant wait, i should be completly swaped in about 2 weeks just intime for the 23and 24th :biggrin:
so who's doing all the work? You.. or you have a shop, or what? I'd love to do a swap, but it would have to be after college (May), but knowing someone that would be willing to help or has the know how would be awesome.
doing it my self with a few friends helping
ummm probably around 1000 $
ummm 1 K ia in parts dude
my clutch was 255 shipped ( Spec 2)
tranny axels flywheel CPS and PCM 525 shipped
shift linkage, trannys mounts, interrior peices petals, 185 shipped
Part name Cost-List price anyway
MTX75 Transmission $1600?new $~700used
Clutch Disc $100.21 Plate $103.20
Clutch Slave cylinder $73.84
Flywheel $94.48
Left half shaft $150?
Right jack shaft $50?
Clutch Master Cylinder $29.19
Clutch Pedal Assembly $178.62
Clutch Hydraulic line upper $15
Clutch Hydraulic line lower $15
Clutch fluid supply line $5
Mount-fender side $85.22
Mount-tranny side-left $41.25
Mount-tranny side-right $40
Mount-cross member side-right $36.97
Shift Tower Assembly $72.97
Shift boot $29 regular $99 leather
Bolts- Clutch to flywheel $2
Friction Modifier $3.60 XL-3
Crossmember $450
Shift cables $45
3 quarts Mobil 1 synthetic ATF $15
Vehicle Speed Sensor-mtx $50
134Kohm resistor $1
Going off that list (the list for the cougar atx to mtx swap how to).. it will cost app. $2380. But that seems high and I'm sure you could get a lot of those parts free/cheaper then listed. I'm sure zx2 parts are cheaper though.
