It was a little bit of a process, but I had to remove the factory fog lamps, remove front bumper, and roll out the gutter guard onto the openings which I completely removed all stock grilles, then bent the guard till it shapes to edge of openings on the inside so its all flush, then screw the remaining overhang into the bumper form(white plastic inside front bumper)replace with aftermarket 85watt PIAA fog lights,and there ya have it, as for the top grill, just cut and bent the metal till it fits-
EDIT- I dont reccomend the high watt fogs, in the pic i had them, but i replaced them with some WAL-MARTS...****ty but they work..the higher wattage just meant needing to replace most of the factory wires.
