F
firingpin
·Guest
lowbeams(dim)
I posted on here a few months back about my lowbeams being really dim. well i finally did what someone told me to do on here and it worked out great, i put a set of high beam bulbs in replace of where the low beam bulbs go, the only thing i had to do is make 2 groves on the plug that goes into the back of the bulb. The high beam bulbs have to little plastic ridges protruding from them, but the low beams only have one in the center... I just had to be careful and grind two new groves in then i plugged them in and wha laa!!!!
im able to see with my low beams on.......!!!!!!!!!!!!!!!!!!!!!
