1 - 9 of 9 Posts
low coolant light came on a few weeks ago and I filled up the coolant tank with coolant and it remained on. I park on a level surface so i know thats not an issue either. I ordered a new sensor for the tank and put that in yesterday but the light still remains on. I unplugged the battery cable and reconnected it thinking it might reset the computer but that didn't work either. Anybody have an idea of what's going on here?
I have this to, what is the recommended fluid?
Dexcool (orange) is what they start with, but you should fill with the same fluid you have - do not mix Dexcool and standard green coolant, for example.
is a pop sensation
If you are only adding a little bit, I'd just use water to top it off. Distilled would be best, but I'd have to admit that just used tap water in mine.
I still have the same problem, but my resevoir stays underfilled, so thats my own fault. Flush and top off to max line is my best guess.
1 - 9 of 9 Posts
