1 - 13 of 13 Posts
I have a simple question... where is the Crankshaft Sensor located on a 2001 Mercury Cougar, 4 cyl, 5 Spd?
on the passengers side front of the motor just under the valve cover on the fornt edge of the timing cover
That's the CAM position sensor, Jason.
The crank position sensor is down low, very close to the main crank pulley, same side of the timing cover.
EDIT: That's for the V6, though... I spoke too soon. I have no idea where it is on the Zetec... :banghead:
it is on the front drivers side of the engine where the trany is, down on the block by the cat with two wires coming of it, it is attached by one torx screw
Here's a pic of my engine with the exhaust manifold removed. I think that's the crank position sensor where the arrow is pointing.
Super Moderator
i fail :(
cbman's photo shows it correctly.
So its begun.....
Zetec section ladies...Zetec. :biggrin:
Screw you, Darkman :rofl:
It was in the PROBLEMS section when it was originally posted.
1993 3000GT VR4
in that case, reading comprehension > you:facepalm::facepalm: :rofl:
So its begun.....
I love this place....:rofl:
Dude, I specified, in my original post (post #3), that I was speaking for the Duratec and I didnt know where the Zetec CPS was located.
This place rules :rofl: :crazy: :goofy:
So its begun.....
What good would that do a Zetec owner? :confused:
:ty:
:grouphug:
1 - 13 of 13 Posts
