Was looking online tonight for an aftermarket oil cap, ran across this. Honda Type R here we come. The list is obviously not complete, hence the lack of any 3L fords or the contique, but it's a good starting point. Figured I'd post this since it's not on here, just some references to honda oil caps in one of cody's threads.
Note: This list is only for cars matching 99-00 Cougars and all Contours/Mystiques, later Cougars used the later twist lock caps. Furthermore, some of these caps use a full thread profile while the Cougar requires a rounded thread profile. See post #2 in this thread.
Year Make Model Submodel Engine
86-87 Acura Legend Base 6Cyl 2.5L
87-90 Acura Legend Base 6Cyl 2.7L
91-93 Acura Legend Base 6Cyl 3.2L
95 Acura Legend SE 6Cyl 3.2L
87-90 Acura Legend LS 6Cyl 2.7L
91-95 Acura Legend LS 6Cyl 3.2L
94-95 Acura Legend GS 6Cyl 3.2L
87 Acura Legend L 6Cyl 2.5L
87-90 Acura Legend L 6Cyl 2.7L
91-95 Acura Legend L 6Cyl 3.2L
86,88-91 Honda Civic Base 4Cyl 1.5L
88-95 Honda Civic DX 4Cyl 1.5L
96-2000 Honda Civic DX 4Cyl 1.6L
2001 Honda Civic DX 4Cyl 1.7L
88-95 Honda Civic LX 4Cyl 1.5L
96-2000 Honda Civic LX 4Cyl 1.6L
2001 Honda Civic LX 4Cyl 1.7L
86-87 Honda Civic Si 4Cyl 1.5L
89-2000 Honda Civic Si 4Cyl 1.6L
88-89 Honda Civic Wagovan 4Cyl 1.5L
88-91 Honda Civic RT 4WD 4Cyl 1.6L
92-95 Honda Civic CX 4Cyl 1.5L
98-2000 Honda Civic CX 4Cyl 1.6L
90-2000 Honda Civic EX 4Cyl 1.6L
2001 Honda Civic EX 4Cyl 1.7L
98-2000 Honda Civic GX 4Cyl 1.6L
2001 Honda Civic GX 4Cyl 1.7L
96-2000 Honda Civic HX 4Cyl 1.6L
2001 Honda Civic HX 4Cyl 1.7L
99 Honda Civic Value Package 4Cyl 1.6L
86-87 Honda Civic CRX Si 4Cyl 1.5L
86-87 Honda Civic CRX 4Cyl 1.5L
86-87 Honda Civic CRX HF 4Cyl 1.5L
89-91 Honda CRX Base 4Cyl 1.5L
88 Honda CRX DX 4Cyl 1.5L
88-91 Honda CRX Si 4Cyl 1.6L
88-91 Honda CRX HF 4Cyl 1.5L
93-97 Honda Civic del Sol Si 4Cyl 1.6L
93-95 Honda Civic del Sol S 4Cyl 1.5L
96-97 Honda Civic del Sol S 4Cyl 1.6L
94-95 Honda Civic del Sol VTEC 4Cyl 1.6L
86-87 Honda Wagovan DX 4Cyl 1.5L
83 Honda Prelude Base 4Cyl 1.8L
97-98 Honda Prelude Base 4Cyl 2.2L
2000-2003 Honda S2000 Base 4Cyl 2L
2004-2009 Honda S2000 Base 4Cyl 2.2L
2008-2009 Honda S2000 CR 4Cyl 2.2L
75-78 Nissan 280Z Base 6Cyl 2.8L
75-78 Nissan 280Z 2+2 6Cyl 2.8L
77-80 Nissan 810 Base 6Cyl 2.4L
81 Nissan 810 DX 6Cyl 2.4L
81 Nissan 810 DX 6Cyl 2.8L
99 Mercury Cougar Base 4Cyl 2L 121CID
99-2000 Mercury Cougar Base 6Cyl 2.5L 155CID
86 Mercury Cougar Base 8Cyl 5L 302CID
88-92 Mercury Cougar LS 6Cyl 3.8L 232CID
86-88,91-92 Mercury Cougar LS 8Cyl 5L 302CID
99-2000 Mercury Cougar V6 6Cyl 2.5L 155CID
86 Mercury Cougar XR-7 4Cyl 2.3L 140CID
89-90,93-97 Mercury Cougar XR-7 6Cyl 3.8L 232CID
94-97 Mercury Cougar XR-7 8Cyl 4.6L 281CID
87-88,91-93 Mercury Cougar XR-7 8Cyl 5L 302CID
2004 Hyundai Accent Base 4Cyl 1.6L
2004-2005 Hyundai Accent GT 4Cyl 1.6L
2000-2002 Hyundai Accent GL 4Cyl 1.5L
2001-2004,2008-2009 Hyundai Accent GL 4Cyl 1.6L
2007-2009 Hyundai Accent SE 4Cyl 1.6L
2000-2002 Hyundai Accent GS 4Cyl 1.5L
2001-2002,2007-2009 Hyundai Accent GS 4Cyl 1.6L
2005,2007-2009 Hyundai Accent GLS 4Cyl 1.6L
2000-2002 Hyundai Accent L 4Cyl 1.5L
2008-2009 Hyundai Accent L 4Cyl 1.6L
2008 Hyundai Accent SR 4Cyl 1.6L
88-94 Lincoln Continental Base 6Cyl 3.8L 232CID
2000-2002 Lincoln Continental Base 8Cyl 4.6L 281CID
98-99 Lincoln Continental Base 8Cyl 4.6L 281CID VIN V
86-87 Lincoln Continental Base 8Cyl 5L 302CID
86-87 Lincoln Continental Givenchy 8Cyl 5L 302CID
91-94 Lincoln Continental Executive 6Cyl 3.8L 232CID
88-94 Lincoln Continental Signature 6Cyl 3.8L 232CID
95 Lincoln Continental Signature 8Cyl 4.6L 281CID
96 Lincoln Continental Anniversary 8Cyl 4.6L 281CID
95 Lincoln Continental Diamond Anniversary 8Cyl 4.6L 281CID
95-97 Lincoln Continental Spinmaker Edition 8Cyl 4.6L 281CID
2003 Suzuki Grand Vitara Base 6Cyl 2.5L
2004 Suzuki Grand Vitara LX 6Cyl 2.5L
2000-2002 Suzuki Grand Vitara Limited 6Cyl 2.5L
2004 Suzuki Grand Vitara EX 6Cyl 2.5L
99-2002 Suzuki Grand Vitara JLX 6Cyl 2.5L
99 Suzuki Grand Vitara JS 6Cyl 2.5L
99 Suzuki Grand Vitara JS Plus 6Cyl 2.5L
2000-2002 Suzuki Grand Vitara JLS 6Cyl 2.5L
99-2001 Suzuki Grand Vitara JLX Plus 6Cyl 2.5L
2000-2001 Suzuki Grand Vitara JLS Plus 6Cyl 2.5L
2001 Suzuki Grand Vitara JLS Plus SE 6Cyl 2.5L
2001 Suzuki Grand Vitara JLX Plus SE 6Cyl 2.5L
2001 Suzuki Grand Vitara XL-7 6Cyl 2.7L
2001 Suzuki Grand Vitara XL-7 Limited 6Cyl 2.7L
2001 Suzuki Grand Vitara XL-7 Plus 6Cyl 2.7L
2001 Suzuki Grand Vitara XL-7 Touring 6Cyl 2.7L
Discussion Starter #2
Though it should be noted that the Cougar uses a rounded thread profile while many aftermarket honda caps are full 70% profile threads. Using a file to cut down the threads works just fine though, but make sure you clean off all the little chips before you test fit the cap.
Discussion Starter #6
Since you have 3L valve covers the answer is no, they will not fit.
You can try to find some aftermarket caps for the 3L though and add them to this thread. Just off hand Volvos, Mazdas, and Jaguars also used the same style plug as the 3L, and some newer Dodge's if rockauto is to be believed.
Discussion Starter #7
Just and update to bump to the top of the section. 01-02 valve covers use the same twist lock caps as 3L engines, this info is now added to the first post too.
Discussion Starter #8 (Edited)
And I'm pretty sure that the thread is M32x3.5 in case any one wanted to fab something of their own up. Will try to confirm when I get home from class tonight.
EDIT: nope, it's M33x3.5
