I replaced my door and window buttons with red led bulbs. It was the standard replacment bulbs with a maximum of 3 volts. I then tried to replace the leds in my center console button assembly. I took off the button cover to my rear defroster and replaced the two bulbs and when i plugged the fuse back into the back of the assembly the bulbs came on and then faded out and now will not come on at all. Do the leds in the center console assembly have a higher voltage requirement? And if so what bulb do any of you suggest to replace it. Any help is greatly appreaciated.
