Umm ok ... the lowest pull toward the front is your Air Conditioning Condenser pulley, and NO this should not wobble... bad bad. Is your AC working properly?
Behind that while still low on the engine is the main crankshaft pulley (it powers the belt to the rest of the accesories) Above that is the Tensioner pulley.. This pulley is meant to move you put a 1/2 inch breaker bar in there to relieve the tension to change a belt. But normaly its applying enough force to take the slack out of the belt, it can go in and out but under normal idle it shouldnt move much.
If the AC pulley realy is wobbling it will probably need to be replaced then have your AC recharged, Unless the condenser is just some how loose but i doubt that. Then again im not sure how the AC pulley would get bent.
Oh and there should be a belt / pulley lable on your passenger side strut tower.
