Does anyone else have an issue with water leaking onto the front valve cover when the car is parked and it rains?
Discussion Starter #3
yeah that ones understandable because of the vent directly above the engine. Im just trying to figure out if my hoods messed up.
No problems with mine. I have since cut out the panel to allow air into the engine bay. Obviously this will allow rain to get in however the car is not a daily driven car anymore.
Discussion Starter #5
well mine still doesnt run atm so its not a daily either. I'm curious if I have a crack somewhere or if its just getting on through the scoop. I guess I could tape it shut before the next rain to see.
It would be the only place I could see it coming in from. From there its likely leaking down the panel below the scoop (the one I cut out) and coming out the hood frame.
