With all this talk about heat soak and bringing outside air in to keep the air temp down for performance got me thinking about something..
Have any of you ever touched your upper manifold after having the car running for alittle while? That MoFo gets hot! So is it really worth it to cut this and snake that to bring in cooler air, just to have it heated right back up from the intake manifold? If anything we should be trying to figure out how to shield the upper intake manifold a from heat along with bringing cooler air in. I believe somebody from CEG got there manifold ceramic coated just for this reason. I know there is no way to keep all the heat out, (lower manifold, heads)... but if we are going to nit pick about gettting cooler air in and heat soak and which intake system is better, we mine as well look at the whole deal.
Right?
Right?
