561 - 580 of 625 Posts
Man, were it not for that stupid top engine mount being RIGHT IN THE WAY of anything fun...
Super Moderator
Discussion Starter · #564 ·
talked with vortech yesterday and they dont have any information on it, and they had those parts made so they couldnt even point me to a supplier. sent me to a couple other places but no luck there either
Gord - The Ford Escape uses a different motor mount on the 3L, and Kenne Bell even had a supercharger setup for it. Although I don't think they sold any....
Super Moderator
Discussion Starter · #567 ·
if i cant find anything from a dealer ill just have to make them. it they really arent that hard to do. the tricky part will be indexing the 3 pins, but we have a tool for that too ;)
the real tricky part is finding the time
Super Moderator
Discussion Starter · #568 ·
Dad got the blower cleaned up, and got all the bolts out and tapped, made new spacers as well. He put the jack shaft in the lathe and there was a bit of wobble, going to stop tomorrow and check it out
Super Moderator
Discussion Starter · #575 ·
My dad worked machine maintaince for a very long time. Said Allen bolts generally have 10-15% more thread contact than a standard bolt. The ones that I got were a higher grade than standard.
I never thought about safety wire, but it’s kinda a ***** to get to, it might be doable with the Allen heads
I was wondering about the allen head statement as well. I know nothing about the design and specification of bolts. What determines a bolts thread contact? I assume it has something to do with how deep the threads are cut, but then I'm sure there are fine limits there. :shrug:
Interesting topic for discussion.
Gord's right, the thread form is the same unless you buy really special fasteners, and hex head or socket head it's all rolled thread with a 60 degree profile.
A higher grade fastener is harder, meaning it'll take more load without permanently deforming, but when they do deform it's not by much before they snap all together, rarely will simply increasing the grade of fasteners do much good if you were breaking them to begin with as they have similar "Ultimate Strength" to lower grade fasteners. It's usually better to either upsize a fastener or increase the number.
Threaded fasteners might as well be called threaded un-fasteners. When you think about them as a basic machine, they're an inclined plane rotated about an axis, and things roll down an inclined plane. In practice this means that vibration causes loosening of fasteners. The contact area of the bolt head has a lot to do the resistance of a fastener from unscrewing, this is part of why all suspension fasteners have an extra large flange on them. Washers aren't much good at preventing unthreading, even spring washers, about the only system that really works are Nordlock's and that stuff's pretty expensive.
In short, use loctite, or tap out the hole bigger.
Good stuff! I knew there was a reason in my head I wanted a flangged bolt head when I recently needed to source a new bolt for my oil pump that I stripped the threads out. BTW 108 in/lbs is not the same as 208 in/lbs. :banghead:
