So I have an issue. I blew out one of my front tires... luckily while in my garage. But by blowing out a tire, I've made an already impossibly low car... even lower.
I can't fit my floor jack under the former jack points any more because the Razzi Kit is in the way. So I bought some Rhino Ramps and successfully placed my front tires on those thinking I could just jack from existing points since the car would be high enough to slide the floor jack under the razzi. I was right... but did not count on the ramps going farther than the stock points.
I could continue jacking on the rail about a foot back from the front tires, but then the neons are in the way. They are just close enough to the rails that if I try and jack up there... I'll crack them.
so... I can't seem to jack my car up to remove that wheel to get the tire fixed. Any ideas?
Only idea I have left is to jack up from the front some how. But I can't figure out where to jack from... I still have a splash guard so I can't see any frame.
Please help. Thanks!
